HYDROS Control System for a
Nano Reef Tank
For the Busy Aquarist
This HYDROS Control setup is ideal for the hobbyist who owns a small saltwater aquarium and wants to add automation elements to their system (this example uses a 20-gallon nano tank). This setup aims to make maintenance easier for the hobbyist with pH monitoring and automatic dosing. The addition of a rope leak sensor also provides peace of mind knowing that if a leak happens, he or she will be notified immediately.
Aquarium Details
Size: 20 U.S. Gallons
Type: Saltwater
Age: 2 Years
Fish: Clownfish
Equipment Used
Temperature Sensor, pH Probe, Dosing Pump, Rope Leak Detector, Light, Heater, Filter, Control X3, WiFi Strip
The HYDROS App Interface
For The Nano-Loving Aquarist
This setup includes three (3) inputs for the temperature sensor, pH probe and rope leak sensor and four (4) outputs for the doser, heater, light and filter.
With the user-friendly HYDROS App, you can create rules and set schedules. For example, you can turn the output and wifi devices on or off. Also, if the temperature sensor reads a temperature that is too hot for your tank, you can set a rule that will turn off your heater when the temperature goes above a certain level.
Are you ready…
to take full CONTROL of your aquarium?
The HYDROS product line offers several different controllers. Each controller caters to the different needs of an aquarium, making it incredibly easy to find the right unique setup for your tank. The best part, the Controls can adapt to your changing or growing aquarium. Unlike other popular controllers, the Control device you purchase today will work with any HYDROS products available in the future. All of the Controls have the ability to work together – allowing you to manage all of your aquarium’s devices from one single interface on the HYDROS App. This feature is called the Collective and it is what sets the HYDROS Controls apart from other controllers on the market.
We would love to help. Fill out the form and a CoralVue HYDROS representative will be in contact with you soon.
