HYDROS Control System
for Multiple Tanks
For the Tank-a-holic Aquarist
This HYDROS Control setup is ideal for the hobbyist who owns multiple aquariums and is interested in an automatic control system that makes monitoring devices on multiple tanks as easy as possible. Check Temperature, pH levels, detect leaks and control lights, filters, and heaters all from one app interface. The HYDROS Control System is a perfect fit for the tank-a-holic because as the tank count continues to grow, the Control System is capable of growing right along side it, both easily and affordably.
Aquarium Details
Size: 75 U.S. Gallons; Nanos
Type: Planted Freshwater
Age: 2-5 Years
Fish: Tetras, Bettas
Equipment Used
Temperature Sensors, Rope Leak Detector, WiFi Fish Feeders, Heaters, Lights, Filters, Under Cabinet Filter, C02 Tank, CO2 Solenoid, pH Probe, WiFi Strips, Control XS, Control X4
The HYDROS App Interface
For The Tank-a-holic
This setup includes seven (7) inputs for the multiple temperature sensors, rope leak detector and pH probe, seventeen (17) outputs for the heaters, lights, filters, CO2 tank and solenoid, and ten (10) WiFi devices for the WiFi fish feeders and WiFi power strips.
With the user-friendly HYDROS App, you can create rules and set schedules. For example, you can turn the output and wifi devices on or off. Also, if the temperature sensor reads a temperature that is too hot for your tank, you can set a rule that will turn off your heater when the temperature goes above a certain level.
Are you ready…
to take full CONTROL of your aquarium?
The HYDROS product line offers several different controllers. Each controller caters to the different needs of an aquarium, making it incredibly easy to find the right unique setup for your tank. The best part, the Controls can adapt to your changing or growing aquarium. Unlike other popular controllers, the Control device you purchase today will work with any HYDROS products available in the future. All of the Controls have the ability to work together – allowing you to manage all of your aquarium’s devices from one single interface on the HYDROS App. This feature is called the Collective and it is what sets the HYDROS Controls apart from other controllers on the market.
We would love to help. Fill out the form and a CoralVue HYDROS representative will be in contact with you soon.
