HYDROS Control System for a
50-Gallon Freshwater Tank
For the Traveling Aquarist
This HYDROS Control setup is ideal for the hobbyist who loves to travel and owns a mid-sized freshwater aquarium (this example uses a 50-gallon tank).  The goal with this setup is to be able to leave your home for days at a time and know that the fish are fed and cared for while away. The addition of leak sensors also provides peace of mind knowing that if a leak happens, you will be notified immediately.
Aquarium Details
Size: 50 U.S. Gallons
Type: Freshwater
Age: 3 Years
Fish: Angel Fish
Equipment Used
Temperature Sensor, Water Level Sensor, Rope Leak Detector, WiFi Fish Feeder, Lights, Heater, Filter, Control XS, WiFi Strip
The HYDROS App Interface
For The Traveling Aquarist
This setup includes three (3) inputs for the temperature sensor, water level sensor and rope leak sensor, three (3) outputs for the heater, lights and filter, and one (1) WiFi device for the WiFi Fish Feeder.
With the user-friendly HYDROS App, you can create rules and set schedules. For example, you can turn the output and wifi devices on or off. Also, if the temperature sensor reads a temperature that is too hot for your tank, you can set a rule that will turn off your heater when the temperature goes above a certain level.
Are you ready…
to take full CONTROL of your aquarium?
The HYDROS product line offers several different controllers. Each controller caters to the different needs of an aquarium, making it incredibly easy to find the right unique setup for your tank. The best part, the Controls can adapt to your changing or growing aquarium. Unlike other popular controllers, the Control device you purchase today will work with any HYDROS products available in the future. All of the Controls have the ability to work together – allowing you to manage all of your aquarium’s devices from one single interface on the HYDROS App. This feature is called the Collective and it is what sets the HYDROS Controls apart from other controllers on the market.
We would love to help. Fill out the form and a CoralVue HYDROS representative will be in contact with you soon.
